jaycocamprs's avatar
jaycocamprs
GM truck with puck system
Looking at upgrading the truck. Was wondering what issues people had run into with GM's factory mounts. Most likely if we go this route would go with the B&W RVK3700.
  • TimnJo wrote:
    Hi dfletch,
    I have a Silverado 3500 DRW on order and am debating the pro's and con's of the B&W and the Curt.
    My BIL has a B&W which he loves as he's able to separate it making two easy to lift parts and he can remove it by himself.
    My dealer says the Curt is about 200 Lbs - no way I'll be able to handle that myself and I don't think it comes apart, could you confirm?
    You can separate the head from the Curt Q20. Just 2 pins and it pops off. I didn't want to bother with lifting any of it into the bed of my truck since I'm typically doing this stuff on my own. I installed a large U-bolt in my garage ceiling secured to roof trusses. I leave a chain hoist hanging from that and use the hoist to lift the hitch in and out. When out of the truck I use a furniture dolly to wheel the hitch in and out of it's storage spot.
    This is a super easy and VERY SAFE way to lift a 200 lbs chunk of steel.
    KJ
    Fine hitch. i don't know specifics on the GM puck system but I love the OEM pucks in my RAM. Installation or removal of the hitch is simple and takes less than 15 minutes.
    KJ
  • Hi dfletch,
  • I have a 2017 Silverado 3500HD DRW with the puck system. I got a Curt Q20 hitch from Etrailer and just dropped it in. Works great and takes all of 10 minutes put in or remove. When out of the bed just pop plastic caps in place and have a smooth bed for other stuff.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
