- Ralph_CramdenExplorer II
theoldwizard1 wrote:
Many small engines now use metric size fuel
Hmmmmmmm? On the molecular level?;) - pnicholsExplorer III do about what the OP is asking about - we have a small Class C motorhome with a well performing built in Onan generator. However, at all times we also carry along a Honda portable generator and extra gas for it.
The small Honda is for battery charging so as to not have to run the Onan for hours or idle the engine and use it's alternator for hours.
I carry spare gas for the Honda in an exterior storage cabinet in a steel safety can, very similar to this one (it's not inexpensive, but safety is priceless): https://www.amazon.com/Eagle-U2-26-SX5-Safety-Flammables-Capacity/dp/B002M3DY9W/ref=pd_sim_86_1?_encoding=UTF8&pd_rd_i=B002M3DY9W&pd_rd_r=3e80adeb-c143-11e8-ae31-29c6b27af72b&pd_rd_w=y6M57&pd_rd_wg=4oaTR&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=56838e6b-66d4-41e0-a762-743f1a1a628a&pf_rd_r=ZGHGBC2WT5SN39H1XM1S&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=ZGHGBC2WT5SN39H1XM1S - RGar974417Explorer
luberhill wrote:
I didn't know. He just had a Winnebago. They also make trailers.RGar974417 wrote:
I made a wooden box that fits the gas can with a piece of rubber on the bottom. I have that in the pick up bed. I have seen some people with a welded bracket on the tongue where they keep a 5 gallon can.
This is a motorhome - LantleyNomad
luberhill wrote:
D.E.Bishop wrote:
I'm not so sure that you even need a generator if you rig has an on board genny. Do you plann on doing extensive boon docking? Or are you just thinking in case of the on board generator failing? Are you worried that the on board genny will use too much fuel?
Just to answer your question, well to tell you what I do really, I have a 2 gallon saftey can that I carry in the basement compartment with the genny with a full tank of fues.
Is it safe? As safe as any suggestion you have received so far.
Just thinking the Hondas are a LOT quieter than my 4000 Onan...and yea just in case I guess
On your first trip I'd go without it. You will figure out your style in time. There is no need to carry gas can and gensets on your first trip...just in case!
If you need electric use the Onan. - luberhillExplorer
wanderingaimlessly wrote:
Since you are looking at a first trip, dry camping with a "new to you" motorhome. Why bother with it for this short trip?
From all the questions and concerns you have voiced recently, may I suggest you simplify some.
Take the trip, keep carry along gear to a minimum and use the built in systems fully. ie full water/propane tanks, empty waste tanks, and use the unit as the builder designed it for. Then after getting a basic idea of how long batteries, water, propane, etc last, and what doesn't last as long as you had hoped, then start finding ways to enhance it.
From your post, I can almost envision you working yourself to death trying to do everything possible on this first trip, and not taking the time to relax and enjoy it.
Yea you nailed it..this thing is driving me nuts because as always I want everything PERFECT...OCD I guess...seems like lots of little things, the sealant around the roof edge (redone by me), small cracks in the upper shower surround by the screws,two hydraulic lines on the levelers I replaced, now the others...do I replace now or wait till IF or WHEN they may leak ??, its only a 5 yr old unit with 16k miles it seems like NOTHING should be wrong...
Good luck. - luberhillExplorer
Just thinking the Hondas are a LOT quieter than my 4000 Onan...and yea just in case I guess - STBRetiredExplorerAs to the original question, I occasionally carry a small gas can for fuel for a gasoline powered blender. My wet compartment has a metal floor that extends up about 2 inches. It could probably hold 5 gallons of liquid. It also has the big screw in plug in the floor for the drain hose. That is where I put the gas can when I bring it with me. If it were to spill, it would be contained and I could drain it out the hole if need be as there is nothing under that. It is directly opposite from the Onan.
- DrewEExplorer II
luberhill wrote:
Mich F wrote:
Go back into your profile, then go to preferences, then add your RV details in your signature. I'd suggest adding that it's a Class A. There are so many makes and models out there, it can be very confusing.
Ok just changed it,,still don't see it showing up nor do I see yours ??
It's showing up for me. The site only puts the signature on the first post by a person on the page; if there are any more, they don't get the signature appended.
There is an option in your preferences to enable or disable the display of signatures at all (My Forums at the top of the screen-->My Preferences). - luberhillExplorer
Mich F wrote:
luberhill wrote:
MarkTwain wrote:
Be safe. Have an auxillary fuel tank with a gas hose attached and fit into the bed of your truck.
No truck this is a motorhome, I added the info to my profile but not sure if its showing up ??
Ok just changed it,,still don't see it showing up nor do I see yours ?? - LwiddisExplorer IIOP needs to chill. I agree with Wandering. Camping should be fun, not stressful. The generator's own gas tank will probably be enough...just like 60 gallons of fresh water.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
