theoldwizard1
Sep 25, 2018Explorer II
luberhill wrote:
If I carry a small Honda gen do I carry a gas can or someone was saying cut the Onan gen fuel line and put in a T and a hose ??
IF you are familiar with small gas engines and can locate the fuel pump and there is a reasonable enough hose after the fuel pump to splice in the tee, go for it. The outlet of the tee must have a good brass shutoff.
Parts required :
• Brass or fuel compatible tee
• Brass shutoff
• 6 hose clamps
• Fuel hose (you can you clear vinyl hose, AFTER the shutoff
I am not a fan of worm gear clamps on small hoses. Too easy to over tighten. I bought and assortment of spring clamps and use those.
All small gasoline engine are different, but older lawnmower style engines typically use 1/4" ID hose, but not what you buy at an auto parts store. Auto fuel hose is usually 1/2" OD. Small engine fuel hose is usually 7/16". Many small engines now use metric size fuel
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: Feb 21, 2025
