twodownzero
May 29, 2019Explorer
Cummins12V98 wrote:twodownzero wrote:
Air your tires up to 80 psi and don't worry about it.
A RV that has D tires that inflate to 65 based on max load. Now has E why run max?
Because that is what Goodyear recommends, that is what will keep your tires from getting hot and failing, and because there is absolutely nothing to gain from inflating the tires to anything less than the maximum. I'm pretty sure we've had this discussion before and you have your position and I have mine. While truck tires should be inflated based on load, trailer tires should be inflated to their sidewall maximum.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
