philh
May 29, 2019Explorer III
Turtle n Peeps wrote:
Kill the high side alarm and keep the low side.
If you really want to end this business; drain and fill the tires with nitrogen 3X's. That will stop all of this.
Nitrogen is a scam
OP, what does your high quality tire pressure gauge read in comparison to your TPMS read out? that will tell you what pressures you need to know.
I have no idea what Nitrogen 3X is, but if it's being sold as a tire solution it's a scam.
One of the common statements supporting N, is water vapor in air. Most (all?) tire shop air lines go through a water separator filter. Is it completely dry, no, but it's dry enough. Tire temperature would have to get deep into 200°F to "boil" the water vapor. If you're tire is 250°F, you're already in deep doodoo.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
