MFL
May 29, 2019Nomad II
Rob... what Ron means is to weigh each axle/tire, and look up load chart for the weight of the heaviest tire/wheel, then add 5 lbs to whatever the chart recommends. Myself...I'd just go 75 lbs. minimum, but likely would use 80 psi, to take full advantage of the E-rated tires, as well as keep them running cooler. JMO
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
