TNRIVERSIDE's avatar
TNRIVERSIDE
grease on TT brakes. what will happen?
I pulled my TT brake durms to inspect and repack the bearings. I was surprised to find a small amount of grease on the outside of the seal. Fortutaly there was no grease on the drum or business side of the shoes. With only 5,000 miles I did not expect to see a seal failure. I did NOT add grease using the grease fitting on the axle. So hear the question.
If I had added grease to the bearings using the fitting on the axle with the failed seal what would be the outcome other than grease on the shoes and an expensive repair bill?
Would there be only brake failure?
Possible fire?
  • No, you don't need new brakes. Clean them good with Brakcleen then lightly sand the shoes with 120 grit sand paper. They will be fine.
  • Just loss of braking efficiency. I've had it happen. You'll need new brake shoes if they get lubed.
  • Loss of braking action. Brake shoes once contaminated can never be cleaned. They just become garbage.
