Swamp_Man's avatar
Swamp_Man
Grease in New Brake Assemblies
I post this due to the number of complaints I have read on at least two forums where grease has been found in brand new brake assemblies on new trailers. The owners usually report little or no brake response and when the brakes are disassembled, grease is found on the shoes, drum, and in some cases, the backing plate. If you have a new trailer and you even suspect that it does not have the braking performance you think it should, take it to the dealer and have the drums pulled. There are several axle manufacturers who are supplying the over greased axle/brake combinations.
