MrWizard
Dec 18, 2015Moderator
Yes put a nut where one does not exist
Replace sheet metal screws holding things together
By putting a nut in a hole of the rear piece
A good use I have found
Is placing a nut in a hole in fiberglass or sheet metal when replacing running lights, and use machine screw to hold the new light, instead of wood screws in fiberglass
For fiberglass..light due duty tool and aluminum nut inserts
The compression needed for the Steel Serts is too high and will crush the fiberglass
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
