SteveB
Feb 27, 2014Explorer
Those tiny trailers do not use cambered axles. My 1990 utility trailer had the axles mounted on top of the springs originally. It was made out of sheet metal bent into a channel with the stub axles welded onto it. The material was much thinner than the one pictured. I have since made new tubular axles (tandem) and mounted them under the springs. In the end as long as you don't exceed the 1000 pound capacity of the trailer that axle would be fine.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
