holstein13's avatar
holstein13
Explorer II
Aug 16, 2016
Has anyone ever used a 45 AMP adapter?
I usually require a 50 amp outlet to power my coach but sometimes, all I can get is 30 amps.
A year ago I saw this nifty 50 amp adapter that had two ends, a 30 amp male plus a 15 amp mail leading to a 50 amp female. The problem is, it doesn't work.
Every time I plug it in, it trips the 15 amp breaker on the pole. If I only plug in the 30 amp, I get an "Open Leg" fault" on my display. I've tried it at 3 different places always with the same result. Do these things even work? How can I test it with my voltmeter?
And I'm sure that someone will mention that 50 amp power is actually 100 amps total. I realize this so there is no need to mention it. But I'm sure it will get mentioned anyway. Few people read to the end of these posts.
ON EDIT: I should have mentioned that I have two adapters, this 45 amp and a 30 to 50 amp adapter. I use the regular adapter every time I have 30 amp available but not 50 amp. I was just hoping to use the 45 amp adapter occasionally.
EDIT #2:Thanks to the very informative tips, comments and suggestions on this post, I have decided to ditch my 45 AMP adapter and I switched to a 60 amp adapter (two 30 amps for a total of 60 amps). I am writing this comment from the glorious comfort of my coach cooled by two air conditioners. It's not as good as 100 amps, but it's better than 30.
Thank you all for your input. This is why I love this forum so much.
