Chainwright's avatar
Chainwright
Have You Tested the Class As or Cs built with Hybrid Motors?
This is a Class A or C question. AS always I encourage global participation, because you may know someone or of someone, or you may have a friend or friend of a friend. You get the gist.
Has Anyone ever tested a Class A or C with a Hybrid motor (like a Prius or chevy Volt). I know in 2009 Fleetwood and Winnebago were toying with the Idea and a Frightliner (Fred) Hybrid chassis was developed. I think a few came out in 2014.
  • Ok so far this is what I found. DrewE was very close, westend thanks for looking in that direction.
    http://rvlife.com/hybrid-rvs-make-debut/
  • There is almost 0 reason to do this. Anytime you go from one energy type (in this case mechanical to electrical) you lose efficiency. Batteries just don't have enough energy density with an RV that weighs 15, 20 30 thousand pounds.
  • The closest to a hybrid motorhome would be what Roadtrek does with their "engine generator" and VoltStart system, where when the batteries get low, the engine starts and runs for a bit to charge them.
  • DrewE's avatar
    DrewE
    Explorer III
    I'm not aware of any hybrid motorhomes actually being made. That's not to say they don't exist; I had not heard of the Fleetwood/Winnebago/Freightliner work, so I'm far from fully informed on the matter. These days I would imagine the most likely source for one would seem to be a conversion from a hybrid city bus.
    In general, the fuel economy improvements of a hybrid drivetrain are mainly under the sorts of conditions where motorhomes are less likely to be used: start and stop city driving rather than extended highway cruising. In my mind, the main advantages a hybrid motorhome could offer have more to do with the possibility of integration with the house systems, particularly the house electrical system. If the hybrid battery pack were also the house battery, there would be a lot more power available than typical, making an all electric coach more practical for boondocking etc. Presumably the main engine could also serve double duty as the generator, recharging the battery when needed, and saving the weight and maintenance needs of a separate generator. My suspicion unfortunately is that many RV makers would be fairly slow to adopt that sort of integration if they did offer a hybrid motorhome.
    It would also be nice to be able to quietly trundle in and out of a campground at night (without having to start the engine).
  • I've never heard of a hybrid Class A or Class C. Do you have a link or any more info them? It sounds interesting.
  • Rather than a hybrid motor or engine, this would be better defined as a hybrid drive train. The Volt and Prius have both electrical motors and a gas engine.
    No, I haven't driven one, nor have I seen any.
