- Bionic_ManExplorer
free radical wrote:
mr_andyj wrote:
These clowns tested a mid-sized truck with a 6,000 boat. Same hill. 3rd gear, rpm's screaming at near redline. They thought, no problem because they were able to maintain speed limit. 3mpg sounded good to them, clowns.
Not reality.
Who does that to a truck they own? Nobody, you tow the thing 20-30 mph slower because it is a mid-sized truck and you already know you will have to take it easy.
Now, if the test were: lets tow where the truck seems to be comfortable and we are not putting extreme stress on an engine/trans that we hope to keep for 200,000 miles, then I would pay attention to the comparisons, because that is how people drive, normal.
X2
Actually, as someone who runs the pass many times a year, I would say the vast majority of drivers put their foot to the floor, and run either the speed limit, or as fast as their vehicle will tow. - free_radicalExplorer
Not reality.
X2 - mr_andyjExplorerThese clowns tested a mid-sized truck with a 6,000 boat. Same hill. 3rd gear, rpm's screaming at near redline. They thought, no problem because they were able to maintain speed limit. 3mpg sounded good to them, clowns.
Not reality.
Now, if the test were: lets tow where the truck seems to be comfortable and we are not putting extreme stress on an engine/trans that we hope to keep for 200,000 miles, then I would pay attention to the comparisons, because that is how people drive, normal. - My take away from this test.
The F150 towed the load the easiest which should translate to a more enjoyable towing experience.
The Ram made the best fuel economy while towing
The squat and brake applications are essentially the same for both trucks
Both trucks did not benefit from the electric power feature in the up hill towing process, but may have helped with grade braking. - goducks10Explorer
mr_andyj wrote:
Those guys put a weighted trailer on, floor it and go up a steep hill at an altitude few will ever see on a regular basis. Is this really the standard which you will judge a vehicle?
Well it's apples to apples for comparison reasons. If a truck wins the Ike challenge then it will be that much better in normal conditions. It's all relative sorta.
I agree though I'm not all that impressed with their methods. My Ram CTD would lose on the Ike every time, but in the real world I have zero issues towing in the mtns or anywhere else.
The speed limit, road conditions, weather conditions and trailer tires or how much fuel we want to burn govern how fast most of us get to where we're going. - mr_andyjExplorerThose guys put a weighted trailer on, floor it and go up a steep hill at an altitude few will ever see on a regular basis. Is this really the standard which you will judge a vehicle?
MitchF150 wrote:
$70K for those trucks... Ha, ha.. I paid $36k out the door for my 13 F150 Eco brand new and would not trade them straight across for either of those even with just over 100k miles on my 13... ha, ha...
I like to 'drive' my truck.. Not let technology 'drive' it for me.. ugh..
I've been using 'premium' fuel in my F150 since I got the new TT and it's made a difference for sure. Otherwise, I would not do it..
Found that out the first time I towed the new TT with regular and the next time with premium..
Whatever.. Do whatever and get whatever you want or need to make you happy. In the end, that's all that matters so who cares what the other guy is doing?
Mitch
What differences did you notice using premium vs regular? I've played around a little, towing with both, and I don't think I can notice any difference in my EcoBoost. wintersun wrote:
No evaluation of engine braking going down the grade which is even more important than MPG going up the grade.
They did evaluate engine braking going down the grade:
Ram - 9 brake applications
F150 - 10 brake applications- $70K for those trucks... Ha, ha.. I paid $36k out the door for my 13 F150 Eco brand new and would not trade them straight across for either of those even with just over 100k miles on my 13... ha, ha...
Mitch
- wintersunExplorer IIHigher octane gas does nothing unless the engine has a higher compression ratio and will knock or have the spark ******** by the engine computer under load. Octane is not a measure of btu from a gallon of gasoline but rather its resistance to pre-ignition when the fuel enters the hot cyclinders of the engine. Pre-ignition results in the engine computer retarding the spark advance and this reduces the power output of the engine. Putting high octane rated gas in an engine than it was designed to use accomplishes nothing for the engine but does help increase the profits of the oil companies.
The 89 Octane is a "plus" in that it is rated higher in terms of pre-ignition than regular 87 Octane gas. Octane is also not linear so mixing 1 gallon of 93 and one gallon of 87 octane gas does not result in 90 Octane but a mix closer to 92 octane in terms of pre-ignition.
Poorly done test. The guys should have driven both trucks up the grade at 55 mph using cruise control and then noted the MPG with each. They also do not understand how Tow Haul mode works as it is designed to keep the ATF cooler but keeping the torque converter clutch engaged longer between shifts and nothing more.
