calewjohnson's avatar
calewjohnson
Heat Coil
Receiving a new trailer next week, Outback 323BH. Saw an add on for the AC, a heating element. Thought it would be a great idea for the cool mornings, just to knock the chill off. I know this is counterproductive if in freezing weather, since the heat won't go into the belly........ With that being said, how does it control the temperature? Do I turn it on fan? Looks plug and play, but if I select heat on the thermostat, it kicks the furnace on.... Thanks in advance!
Cale
  • the A/C fan moves too much air to do any good with the heat strip. as mentioned, a waste of money. I had one and I really should have bought something else with that money.
  • A heat strip does little more than warm the air.
    Had one years ago. Real waste of $$.
    Get yourself a heater you can plug in. Put in a location that best works for you.
  • Hi path1,
    And what exactly is wrong with 5118 btu's? (btw that is 50 candles).
    To the OP, my thermostat has a setting for heat strip.
  • We decided no way. Look at the BTU's it put out, Better off lighting a candle IMO and just something else to break.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
