mowermech
Oct 28, 2020Explorer II
Keep in mind that the propane furnace also heats the chamber where the tanks reside. A portable electric heater will not heat those areas, unless you run the furnace fan without heat, IF your thermostat will allow that (Mine won't.).
The instructions for many portable 1500 watt electric heaters state that they should not be operated while asleep. Sure, it is a CYA for the manufacturer, as required by corporate lawyers, but it is something to consider.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
