SDcampowneroper
Oct 28, 2020Explorer
propane nearly always works out as more economical / BTU over electric. Here at home with elec at .15 , propane at 3.50 elec. is alittle cheaper. Is Az. last winter with elec. at .22c and propane at 2.25 propane was considerably cheaper.
Theres no constant rule of thumb, other than when BTUs match, which is the math you will have to do wherever you are and the cost of each.
Add in the conveniece factors, the need to heat water systems- which elec. does not do well, the chioce is yours depending on your rig.
' tunas calculator is scientifically wondeful, only you can put in the variables.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
