travelnutz
Nov 01, 2020Explorer II
Wow, 16.5/KWH is crazy expensive as here at owned home our electric power is 9.6/KWH and when in our Florida CG with our RV it's 10.3/KWH. Both states forbid marking up the resale of propane unless you are a licensed propane dealer open to the public or the producers of the electrical power. CG must pass on the price paid per measure in these 2 states but others may have different laws to enable them to rip you off.
Our Florida CG we stay at used to have a mobile propane truck go thru every 2 weeks and could refill 20, 30, and 40 lb portable tanks but the new law down there is only 100 lb plus stationary secured permanent or RV built in propane tanks can be refilled by a mobile propane service. Means you have to take them to a propane dealer to be refilled. Our family owns CG's in Florida and I served on the Board Of Directors at a huge GC resort in Michigan.
Propane is about the same price in both places, here in Michigan and in Florida per gallon at a dealer at .98 and 1.02 /liter. 1 liter = 1.06 quarts. 4 quarts = 1 gallon or 3.8 liters = 1 gallon.
The difference is at home on the 2nd Saturday of each month the propane at Redi Rental is 1/2 price so you need to have an extra 30 lb tank etc or 2 so you can span the time of a month's usage without running out. Thus, if doing so, propane does work out cheaper. If not 1/2 off, otherwise it's much closer to being the same cost for either for heating. A few degrees below freezing means the RV furnace must send some heat to the liquid tanks and if colder the plumbing lines also.
All depends on what you have to pay for either the propane/gal or the cost per KWH as to which is cheaper.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
