GrampaR123
May 26, 2013Explorer
If you're measuring the distance on the car from the tow bar receivers to the ground, our Roadmaster tow bar receivers on our 2013 CRV are less than 14 inches from the ground, but by the time the tow bar hardware is inserted and attached the tow bar fastens to the car at slightly higher than 18 inches from the ground. A 4" drop receiver on our 2002 Bounder brings me within Roadmaster's specs for height differential. I'm not sure about other than Roadmaster. I hope this helps.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 31, 2026
