Grit_dog
Aug 25, 2020Trailblazer
OP first realize it’s not an exact science and if it tows well Currently then it’s a good setup. Couple hundred lbs on any axle is not significant or really noticeable. If the front end isn’t floating and the back of the truck doesn’t need more weight removed (sagging) and it drives good, you’re good!
I’m confuse though between pass 2 and 3 your trailer axle weight Should be very close to the same, whether the truck or the Jack is holding up the trailer tongue. Or is that the entire trailer weight in pass 3 including the jack?
And yes it won’t hurt to take more weight off the rear of the truck. If you have reasonable capacity in your wdh.
It also won’t hurt Your vehicle to leave it where it’s at.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
