RCMAN46
Aug 25, 2020Explorer
RobWNY wrote:
I'm confused how you lost 20 pounds completely using WDH bars (14,140 compared to 14,160 for the other two weight rating passes).
I will assume the OP used a CAT scale.
CAT scale weights are in 20 lb multiples. If you look at the OP's weights they are in 20 lb multiples.
I checked several of my CAT scale receipts and they were all in 20 lb multiples.
I also checked some weights I got at my local garbage transfer station and they were also in 20 lb multiples.
Thus a difference of 20 lbs on separate weights can be expected.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
