MHay
Aug 25, 2020Explorer
wing_zealot wrote:
Your WDH is moving 400 lbs of weight out of a total of 940 lbs. That's 42% which is pretty **** good. Your tongue weight is also 12.7% which is good also. The only thing you can do is try to shift 150 lbs of weight inside the trailer so it's off the tongue and onto the trailer axle. If you can't do that, then It's just to much trailer for that vehicle.
Thanks -- that's the confirmation I wanted to get.
I guess I'm still trying to understand how 1,000 lbs. is being added to the axle when the WDH bars are on despite tongue weight being 940 lbs.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
