JIMNLIN
Aug 25, 2020Explorer III
I also checked some weights I got at my local garbage transfer station and they were also in 20 lb multiples.
Thus a difference of 20 lbs on separate weights can be expected.
'zactly.
Just 20 lbs loss or gain is excellent scale numbers.
A first weigh may say 3005 lbs but the scale rounds off to the next highest at 3020 lbs.
The second weigh may say a 2996 lb but rounds off to 2980 lbs for a 40 lb difference.
Wind speed....failure to release the service brakes...fuel/water/liquid slosh in containers/how much fuel was used between re weighs.... can all contribute to different scale weights.
OP...maybe I read it wrong about being over a RAWR I would take some weight off the trucks rear axle. A RAWR is the lessor of a wheel/tire/rear spring pack or the axle itself. Most trucks today weak link can be the OEM wheels or rear spring pack.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
