MHay
Aug 25, 2020Explorer
JIMNLIN wrote:I also checked some weights I got at my local garbage transfer station and they were also in 20 lb multiples.
Thus a difference of 20 lbs on separate weights can be expected.
OP...maybe I read it wrong about being over a RAWR I would take some weight off the trucks rear axle. A RAWR is the lessor of a wheel/tire/rear spring pack or the axle itself. Most trucks today weak link can be the OEM wheels or rear spring pack.
No, you read that correctly. I'm over by 180 lbs. which is why I was trying to figure out if I can move more off of the rear axle with the WDH, or just try adjusting the cargo in the trailer. :(
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
