Mickeyfan0805
Aug 25, 2020Explorer
valhalla360 wrote:
What the GVWR on your truck? I did a quick check online and it looks like 7300lb but you are at 7580lb already but you might have a different model from what I found.
This is the piece of this conversation that I think is getting overlooked in all of this. What is your GVWR, and were you fully loaded, with both people and gear, when you got these numbers? You are not only over RAWR, but likely over your GVWR. If you weren't fully loaded, it means things only get worse from there. If this is a full load, WDH adjustment might help, but that depends on how much you are already dialed in - and you still may be be over weight. If you still have additional passengers or gear to load on top of the weights you are sharing, that just exacerbates the problem.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
