CA_Traveler
Jun 08, 2017Explorer III
familyman5 wrote:Absolutely no electrical difference. However, from a SAFETY standpoint disconnect the negative cable. Why? - Disconnect the positive cable first and connect it to the surrounding grounds with a wrench and you'll have instant sparks and possibly high heat and melting metal or possibly worst.
Do you know if it matters if the positive or negative side is disconnected?
As someone stated above there are some cars that need to be flat towed without the battery been disconnected, not sure if the explorer is one of those. However if it can be towed with the battery disconnected then couldn't I just leave it in neutral and take the key out?
I don't know why one would disconnect a battery cable for multiple towing's versus adding a disconnect switch. I sure as hel* would not be removing battery cables for towing.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
