time2roll
Jun 30, 2016Nomad
dockmasterdave wrote:This overload was with all breakers off except main and A/C correct?
Last try, all breakers were off except main, and a/c.
it ran about 45 mins, and overloaded again.
Does seem odd that the air conditioner would start-run and later overload.
Did the compressor cycle off and back on?
Are you using eco mode?
Best I can say is that you need to measure the power being used and see if it is within the rated amount. One of those kill-a-watt meters should give you a good picture of what is happening.
