MrWizard
Jun 30, 2016Moderator
A Start kit, only helps prevent overload from the high start up current of the compressor, the lock rotor surge amps
It will not help with 'Heat Creep'
Where the load amps goes up because of the increased load trying to cool the RV as outside temps rise, and compressor heat up
Turn the A/C to full cold all the way up so the compressor stays on and does not cycle
If it will not stay running, the only thing you can do is get a bigger generator
