Airstreamer67
Sep 03, 2013Explorer
I would suspect tongue weight. It should be between 10% and 15% of the trailer's total weight. You won't know this unless you weight it.
Also, check wheel bearings, tires, suspension, frame to make sure all the mechanicals are OK.
Find the source of the problem before thinking of a $2500 superhitch that will mask the sway but not cure the cause.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
