Bob_Olallawa
May 23, 2015Explorer
Need to find sheets of the same thickness exterior plywood material, and unless you can remove all the wood and other stuff from the rubber it will need to be replaced as well. The rubber roofing is getting old enough it should be replaced anyway. I wouldn't plan on this being a one day project.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
