B_O__Plenty
May 23, 2015Explorer II
Pull off all the old wood sheathing. Check for water damage underneath it. Replace it 3/8 plywood which is what most manufacturers use. Install new rubber roofing material using proper adhesive. Don't try to salvage any of the old wood or rubber. It's done. This will not be an easy project nor an inexpensive one..
B.O.
B.O.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
