SteveB
Jul 03, 2013Explorer
I have read about this stuff called Break Up Plus.Link to BUP. I plan to get some at the RV store next time I go there. They have a web site so you can read about it. Also, maybe its not paper in the valve. The rubber side seal might be ripped causing the blade to bind up. If you can dump the tank and have access to the valve it is easy to remove. 4 bolts and spread the pipes a little and it should slide out.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: May 12, 2025
