2gypsies1
Jul 03, 2013Explorer III
You said you tried filling the tank again and dumping it. So it IS emptying completely? If so, try filling and dumping multiple times using the regular dump hose, not the macerator. You'll get a faster, more forceful "swish" of water that way. If that doesn't work after a few fills and emptying, sorry, but you'll have to disassemble it. Using a chemical won't dissolve the toilet paper that is caught in your connection assembly. Then, while you're at it, just replace with a new assembly rather than trying to clean. They do wear after a time. Good luck!
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Jan 02, 2026
