daystrom's avatar
daystrom
Help setting up Equal-i-zer to F350
I have a 1,200/12,000 lb Equal-i-zer brand hitch that was setup just right for my F150. My trailer weighs 7,000 lbs loaded and the tongue weighs 1,000 lbs.
I just traded in the F150 on a F350 SRW with the 6.7l Power Stroke. A very stout truck I must say.
I had to lower the hitch head as low as I could since the 350 sits so much higher than the 150.
I'm running into a few problems...
* Not enough weight distribution
* Trailer tongue sits too high when hitched up
Since I have the head as low as it will go I'm guessing I'll need to find a shank that is lower
As far as the weight distribution goes, I've played with lowering the L brackets and removing washers. No matter what I do the spring bars seem loose and don't seem to be moving much weight around.
My measurements are as follows:
Truck alone:
Front - 41 3/4"
Rear - 44"
Trailer connected no WDH:
Front - 42 1/4"
Rear - 42 1/8"
Trailer connected with WDH:
Front - 42 1/8"
Rear - 42 1/4"
If I put the head back up to where it was, the spring bars are way too tight and angled.
Any ideas? Do I need more distribution? It seems to tow fine other than the trailer being too high in the front.
Todd
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Oct 01, 2015
