bud121156's avatar
bud121156
Help with an turn signal (not working) issue.
I had a Fleetwood Westlake pop up camper for 6 years.I tow with an 06 Ford Escape. I have the Bargman connector. From the beginning I had an issue with the turn signal. My turn signals,both right and left, would "freeze" up and not flash if I first didn't tap the brakes to activate the lights. Got good over the years remembering to tap the brake first, then turn on the turn signal. If I did happen to forget, I could turn the car off for around 5 minutes, and I suppose some electrical issue would reset, and the turn signals would flash again.
This weekend I traded the pop up for a KZ Sportsman Hybrid. All along I was hoping the turn signal issue would be gone. Well,after the walk through when we hitched up the new camper, the RIGHT turn signal did not work at all, All the other lights worked great. The technician had some sort of tool he connected to the trailer end of the Bargman that sensed the lights from the tow vehicle. It was legit,cause even though the trailer wasn't hooked to the tow vehicle, the lights on the trailer work, including the before mentioned right turn signal.
With having the same issue with 2 different campers, I figure now the problem is with the Ford Escape. All lights on the Escape work fine when I'm not hooked up to a camper. Looking for answers.....any ideas what the problem may be?
  • Not familiar with the Escape. Does it have separate turn signal lights in the rear from the stop (brake) lamps?
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
