Rice
Mar 16, 2018Explorer III
Rover_Bill wrote:
DW has no patience and blows her top when I tell her - turn right, left, right. She screams: Why don't you make up your mind which way to turn can't you see where I'm going?
Well that's a new one to me.
I would think people would relish having the "expert" tell them which way to turn, and simply follow the directions. Who cares if you're turning left right left right left? Just do what you're told.
Either it gets done perfectly because it's the expert doing everything but actually handling the wheel (which face it, a monkey could be trained to do), or the expert gets humbled because it doesn't work.
No skin off the wheel handler's nose in any event, which sounds like a win to me.
ETA: And when I say do what you're told, I mean verbally, not hand signals. Tell the wheel handler which direction to turn the wheel, how much to turn the wheel, and have them stop between each repositioning of the wheel so you can check the tires and make sure it's set up right for the next maneuver. Almost like operating the RV via remote control. It should make for perfect results every time.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
