- Ron3rdExplorer III
09KZMXT266 wrote:
Thanks all, but I went a different direction. I ordered an Andersen no-sway WDH. Very excited to get it and try it out. Thanks again for all the advice.
There's a growing number of Anderson users out there. Let us know how it works out for you once you set it up. - DutchmenSportExplorerLink to Anderson.
I've never seen this type of system before. I'm still trying to wrap my head around it. - 09KZMXT266ExplorerThanks all, but I went a different direction. I ordered an Andersen no-sway WDH. Very excited to get it and try it out. Thanks again for all the advice.
- coolbreeze01ExplorerI like Blue Ox Sway Pro. Check them out while you are shopping.
- Ron3rdExplorer IIIWhat downtheroad said.
The second hitch he shows is the old EAZ-Lift style hitch, which was the original WD hitch and lots of companies copied. You can add a single or dual friction sway control with this type. The Equal-i-zer Brand hitch has built in sway control. Equal-i-zer has an easy calculator on their site to aid in bar selection in terms of pounds. - downtheroadExplorerOK....
This is an Equal-i-zer Brand hitch. It has some built in sway control in addition to weight distribution
This is a generic weight distribution hitch...a number of manufacturers offer it or very similar. It does not have any sway control components built into it. It is often mistakenly called an Equalizer hitch (confused with Equal-i-zer). An optional friction sway bar can be added to it for some sway control - 09KZMXT266Explorer
Francesca Knowles wrote:
E-trailer has a very informative page that explains how to properly choose/size weight distributing hitch systems. Here's the link.
Whatever size you decide to buy, do understand that unless specifically designed/advertised to do so, WDH systems do NOT serve as/provide sway control, which then must be added on. Too many folks have discovered this the hard way. That part of the equation is also well explained at the linked-to page above.
Are you saying the sway control built-in on some WDH's is not adequate? The Equalizer WDH has sway built in.
Is he talking about that specific brand? Couldn't tell...
I'm just saying that not all WDH hitch systems have built-in sway control. And since the O.P. only asks about weight capacity, I thought it worth mentioning as something to be looked for/at.
I currently have a Pro Series cheapy WDH system. I was wanting to add sway control. Instead of adding a friction bar, I have decided to upgrade to a WDH system with sway built-in. Someone recommended Equal-i-zer brand and it looked promising. I just wasn't sure if I should go 10k,or 12k really.
Now, on another forum everyone is pushing the Anderson No-sway WDH system and I may change my mind to that. :) - Francesca_KnowlExplorer
I'm just saying that not all WDH hitch systems have built-in sway control. And since the O.P. only asks about weight capacity, I thought it worth mentioning as something to be looked for/at. - DutchmenSportExplorer
downtheroad wrote:
Once again here on the Forum with confusion between Equalizer and Eual-i-zer hitches.
Would you please explain the difference between "Euqalizer" and "Eual-i-zer". When I do an internet search of "Eual-i-zer" I get only hits for "Equalizer" and "Equal-i-zer" hitches. And they are one and the same.
What the difference? - downtheroadExplorerOnce again here on the Forum with confusion between Equalizer and Equal-i-zer hitches.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
