hmknightnc
May 31, 2014Explorer
EnochLight wrote:
Wow - thanks everyone! That's something to go off of. Much appreciated.hmknightnc wrote:
What is your axle rating, tire rating, and scaled RV weight.
Here's the funny part (or not so funny part) - both of my Hi Run tires and the spare are ST175/80D13's, but the printed label on the side of TT calls for ST205/75D14C's! Could this be part of my problem?
Cold tire pressure is 50 psi (I usually keep them between 47 psi and 50 psi). GVWR is 3810 pounds, GAWR front is 3500 pounds.
Is this tire size a misprint on your part? You are saying the trailer sticker requires 14" load range C tires and what you have is 13" load range C tires? If that is true on a dealer delivered new TT you have a serious problem with a dealer. And yes if true those 13" inch tires were likely severely overloaded. What is the 13" tire sidewall marked maximum load and max tire pressure?
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
