EnochLight
May 31, 2014Explorer
hmknightnc wrote:
Is this tire size a misprint on your part? You are saying the trailer sticker requires 14" load range C tires and what you have is 13" load range C tires? If that is true on a dealer delivered new TT you have a serious problem with a dealer. And yes if true those 13" inch tires were likely severely overloaded. What is the 13" tire sidewall marked maximum load and max tire pressure?
Well, here's the label:
It came with ST175/80D13's on it, though - spare included. On the ST175/80D13's it states maximum 50 psi cold. Max load is.... 1360 pounds! Wow.... that's just... WOW. That's only a little over 2700 pounds total, which is what my rig weighs dry.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
