EnochLight
Jun 02, 2014Explorer
jaycocamprs wrote:
2,310 lbs dry weight, net carrying capacity 970 lbs. That should equal a GVWR of 3280.
You need ST205/75R14 with a load capacity 1760lbs at a minimum. If it were mine I'd do the ST215/75R14 with a load capacity of 1870lbs. That’s if I couldn't fit something even larger.
gmw photos wrote:
what make and model is this trailer ?
Edit: if it were mine, I would see if 15" would fit. If so, I'd go on up to a good 15, like a G26 Cargo ( goodyear ) load range D.
Far as I'm concerned, when you only have a single axle, you'd darn well better have good stuff under there, with plenty of reserve.
Thanks guys. It's a 2013 Amerilite Ultralite 16BHC. I plan to take the issue to the dealer where I purchased it. Hopefully they'll take care of it. If not, my choice is to sue them in small claims or eat the cost of 2 new wheels with tires and a proper spare that are the correct size and weight capacity.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
