gmw_photos
Jun 02, 2014Explorer
EnochLight wrote:jaycocamprs wrote:
2,310 lbs dry weight, net carrying capacity 970 lbs. That should equal a GVWR of 3280. You need ST205/75R14 with a load capacity 1760lbs at a minimum. If it were mine I'd do the ST215/75R14 with a load capacity of 1870lbs. That’s if I couldn't fit something even larger.
Actually, this is what my trailer label states:
Sounds like if you are anywhere near the gross weight when you go camp, you are close to the limit of even the "correct" size LR C tire. I would look under it closely with a tape measure, and if you have room for a 15" g26 cargo, then I would run those. Personally, I would do it that way, even if I had to buy the new wheels and tires out of pocket.
But I am probably the lone ranger in this discussion approaching it that way.
At best, the dealer is going to give you some 14" wheels and junky ST tires. At least I suppose you could sell them on craigslist for someone to use on the utility trailer they use to go to the dump with.
At the very least, if staying with 14", I would use Kumho 857.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
