Phydeauxman's avatar
Phydeauxman
High and Low settings for TST Tire Monitoring system
I just installed a TST-507 system on my TV and 5th wheel. Put sensors on all tires...including both spares. Wondering what others recommend or have done for setting the high/low pressure and temperature thresholds. I aired all of my tires to 80psi a few weeks ago when the outside temp was warmer and yesterday when I sync'ed everything to the monitor they were all reading in the 70's. Outside air temp was down about 15 degrees from when I had aired them to 80.
  • Bobbo's avatar
    Bobbo
    Explorer III
    I told TST exactly that.
    Funny thing. The TST receiver's battery failed on that same trip. The TST would work as long as it was plugged in, but would die immediately when unplugged. I called TST to find out what battery it was so I could buy a replacement battery, but TST said that even though it was out of warranty, they would send me a new receiver anyway. During the conversation, I told them that it had saved my bacon that very trip.
  • Bobbo wrote:
    I
    Coming home from our last camping trip, the TST actually alarmed high temp on the right front tire. It was showing 160 degrees. The right front brake was dragging and heating the wheel. When I stopped, it was smoking. Ford had to replace the right front brake caliper. I wish it had been under warranty, it was about $412.
    TST paid for its self, that wheel could have caught fire.
  • Bobbo's avatar
    Bobbo
    Explorer III
    When the high temp alarmed, the other tires were showing about 115 degrees, if I recall correctly. I did not really make a point of noticing their temperature.
    Of course, ambient temperature was above 90 degrees.
  • Bobbo wrote:
    I have the same system. My front tires are recommended at 65 psi, and my rear tires are recommended at 80 psi.
    I use 58 psi as the lower limit for my front tires, 10% below 65 psi. I use 72 psi as the lower limit for my rear tires, 10% below the 80 psi.
    Since all of the tires have the same sidewall rating, I use 100 psi for all of the tires as the upper limit. That is 20% above the 80 psi of the rear tires, rounded off.
    I left the temp setting at the default 158 degrees F.
    Thanks for the great, detailed info. Do you recall what the temp was on the other tires as you were going down the road? Just curious.
  • Bobbo's avatar
    Bobbo
    Explorer III
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
