fred42's avatar
fred42
Hitch Cargo Carrier and Flat Towing
I am exploring the idea of a hitch cargo carrier of approx. 30" x 48" that would be inserted into the 2" 5000/500TW hitch on the back of my gas class A. It would need to carry a load of around 80 lbs. I am finding that manufacturers I have seen so far do not offer a 2" hitch receiver on the back of these for my 35 lb tow bar. I am sure this is because customers would assume they could put a 500lb tongue weight on it.
I considered putting the hitch cargo carrier on the TJ Jeep. Some of the potential problems there are: the hitch is very low and may drag, unless removed it complicates access to the back of the Jeep, and may create some Jeep tail wagging that I would not want. In addition to this, I was an idiot when I bought the Jeep and allowed them to install a Class II 1-1/4" hitch that would have to be changed to a 2" receiver hitch.
Has anyone done something similar? Does doing this create any problems I am not seeing?
  • I have a hitch doupler from HF and modified it fot 12 inch separation versus the original 6 inches.
    I now can use any combination of a toad, a cargo carrier and a bike rack (any two)
  • I got a carrier for the MH. Used a double mount receiver. Towed Suzuki through the lower one and placed carrier in upper. Little awkward to connect Stowmaster towbar.
  • You are not an idiot...you just made a mistake on the 1 1/4. Who hasn’t? Bite the bullet and get a 2 inch.
  • I carry a 220+ carrier/mobility scooter on my 14 JGC with no issues and the hitch is very high. I installed a 4" drop adapter to help with ramps and scooter clearance. When the carrier is folded up the back cannot be opened.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
