hikerboy1's avatar
hikerboy1
Hitch height and tongue weight question
I'm getting ready to adjust my Eaz-Lift hitch head height for my new trailer; It's an Outdoors RV Back Country 18F, which has a listed tongue weight of 500lbs. But the 50 gallon fresh water tank is up front under the jackknife sofa, plus 2 batteries and 2 full propane tanks could probably push the weight upwards of 1000 lbs (when the water tank is full). I've read that the ball height should be 1/8" taller than the level trailer coupler for every 100 lbs of tongue weight.
My thought is to start the ball height at about 1-1/4" higher than the trailer coupler to reflect the weight of water, etc. Sound logical? Or should it be less than that, and add more tilt to the hitch head to allow for leveling the heavier loads? I do have 1000 lb bars.
Thanks for the thoughts. Might take some experimenting, but hoping to find the setup that gives me some flexibility in tongue weights.
  • We are pulling with a Silverado half-ton; The axles are Al-Ko Ultralube with standard leaf spring suspension. I'm going to try setting the initial ball height as if no water in the tank, which should put my ball height about 3/4" higher than the leveled trailer coupler height. And adjust from there.
  • I don't travel with fresh water, I wait and fill the tank when I arrive at the campground, then your only going a short distance and things are pretty slow inside the campground.
  • Ivylog's avatar
    Ivylog
    Explorer III
    OP, what are you pulling it with? In looking at pictures of a 18F it may have torque flex axles and from my experience a trailer with those type of axles... no equalizer bar as there are no springs tow better with the tongue a little higher than normal.
  • standard bal height should be around 19 1/2 inches to the top of the ball. loaded or empty
  • What happens when you're done camping and the fresh water is gone? I'd set it up as if no fresh water, that way you'll be a little nose heavy going and right on coming home.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
