DutchmenSport
Aug 03, 2018Explorer
I'm towing a similar size trailer, but am using a 1400/14000 pound 4 point Equal-i-zer WD hitch system. With such a system, you don't need a separate sway bar.
Initially, I towed this camper with an old style Reese with the torsion bars that has the chain links on the end. I used a single friction sway bar and it towed just fine. Of course, I'm also towing with a dually truck too.
The reason I ended up switching hitch systems was because the Reese was over 10 years old and this was the 3rd trailer. The last trailer was heavier than the previous 2 and I think, between age, wear and tear, and the extra weight, the actual hitch head bent downwards and then the sides where the bolts go through the shank bent in such a way that it absolutely could not tighten to straighten the whole thing out. I ended up going with the Equal-i-zer and have not regretted it since.
But, to answer your question, the single friction sway bar, on a similar size trailer as yours, served me well. Never an issue with sway.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
