F1bNorm's avatar
F1bNorm
Home dump station
Having some sewer work done on the house, so I'm thinking why not add a RV dump point? Thinking 3-4 inches high in the flower bed.
Any thoughts? Yay or nay? Where would I look for fittings, caps, lids etc.
Norm
  • ACDNate wrote:
    Francesca Knowles wrote:
    You mean a cleanout/access tee, right?
    I'll hussle on down to City Hall just as soon as you put up links to any municipal system that imposes any such requirement for such a small upfit to a single-residence's sewer line along with the applicable restrictions as to putting sewage into it.
    The point you are missing is that utility systems aren't the most open minded with doing things that a system wasn't designed for. Of course it would work fine, thats not the point.
    :h
    I've actually participated in a long planning process for a municipal sewage system, and can assure you that they're designed to treat sewage. And since "sewage" is what's in an RV black tank.... what exactly IS your (and Mocoondo's) point?
  • From what I've seen, the city is fine with it, provided they get their water/wastewater dues. However, NIMBY syndrome is alive and well.
    :h
    Exterior located sewer cleanouts are OK with my State Code, based on UBC so should carry through most States.
    Not to say that some municipalities may make a regulation against using it to drain sewage from an RV or anything else. Not everyone would like to see their neighbors use the cleanout as a drain.
  • What kind of chemicals are guys using? I am pretty sure any thing that not OK for your septic system the city wouldn't want!
    I use about a 1/4 cup of laundry detergent and dump in my clean out right next to my tank why could it possibly be a problem outher then not wasting a bunch of money and creating a job for someone?
