Bill_Diana's avatar
Bill_Diana
Honda CR-V the night before???
There are many postings about the correct procedure to follow before towing the Honda CR-V. I have a slightly different question.
I have always performed the gear shift routine right before departing with the motorhome. Would it be OK to do the setup routine with the gears the night before departure? Thus I could just get in the motorhome in the morning and drive away.
  • gasser9 wrote:
    The BOOK states every 8 hours whether moving or not. My book has an addendum that requests 7 hours & 5 minutes run time if you go to Reverse or Park another 5 min. It is your $3000 Transmission do what you feel comfortable with.
    gasser9
    What year is your CR-V. I have not seen an addendum for my 2014. I'm paranoid about run times, and more frequently seems prudent.
    As an aside. . . My braking system malfunctioned on the interstate while travelling at 60 mph, and the CR-V stopped the MH in about 200 feet (impressive!). There was mucho smoke from the tires, but it stopped it really straight. . . all tires were squared off very evenly. Cars on the Interstate move very quickly out of the area when there is smoke in front of them, fortunately there was an exit very close.
    After consultation with Honda and Les Schwab (in Anacortes), I replaced the CR-V tires in St. George, UT for about $40 less per tire than Les Schwab. If you ever have tires issues in St George, go to Gene's OK Tire. They were amazing. I had hoped to get more than 1,800 miles on the original Dunlap tires.
  • The BOOK states every 8 hours whether moving or not. My book has an addendum that requests 7 hours & 5 minutes run time if you go to Reverse or Park another 5 min. It is your $3000 Transmission do what you feel comfortable with.
  • I have done both with zero problems! That's not to say that You should follow Mine or anyone else's advice on this forum!
  • I'd also do it just before you leave and for the reasons that OldHatt45 suggests.
    I also tend to do it after we stop for lunch or a break and things have cooled down, and also every 8 hours while towing.
  • I always do mine in prior to taking off, even if the CRV was hooked up the night before. I agree with OldHatt45. Dick
  • Bill,
    I believe the reason for the pre-departure routine is to get the transmission fluid warm and into the places where it has drained out of.
    Doing the procedure the night before would then allow the transmission to cool off and drain.
    Drew
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 14, 2026
