jkbrea's avatar
jkbrea
Honda Generator Cable Question
I bought two Honda 2000 generators years ago and they have always worked perfect. One has the bolt on parralel kit with the 30 AMP plug and circuit breaker with cables to attach to the second one. I need to replace the cable ends that were damaged. I've seen cable kits where you simply plug the connectors into one generator and then the other ends to the second. Mine has the bolt on kit that has one end of the cables permantly attached to it. Is there a difference or can I use the simple cable kit.
  • If you can post a pic of the fronts it will be easier to tell. I have not seen one that did not have the banana style plugs as an option on the front. I would hate to tell you yes and yours be one that does not have it.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
