mrekim's avatar
mrekim
Honda Odyssey Toad Wiring
I need to wire up a 2007 Honda Odyssey as a toad. I have the wire and diodes. It seems as if the wires run inside the body vs along the frame like the other vehicle I wired (Ford Excursion).
Does anyone have any advice as to how to do the wiring - alternate places to tie in, a good path to wire from the tail lights to the front, how to get to the in body wiring by removing interior plastic, etc?
1 Reply
  • On my 03 Honda CRV there are several parts and panels to remove. They go in order as they overlap. I have just forgotten if it was front to back or the other way. Most should just pull off with a bit of effort and there is probably the odd screw to remove. Easy to run wiring once they are removed. Owners manual should have some info as well. Good luck
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
