- Edd505ExplorerPower the OTA power off
Go into TV menus, select cable
Scan for channels
Watch Cable TV - ScottGNomadTurn your wall ant power supply (some wrongly call it the amplifier) OFF.
- westernrvparkowExplorer
Jack Spratt wrote:
On most TVs you then need to scan for channels.
Menu
Channel
Antenna/air——cable—-hdmi. Select cable - luberhillExplorerYea I don’t think you want the tv in 3 or 4 because there is no cable box
- Combo of what Germania and Jack has posted. Turning off the antenna amp is the first thing, then do the TV incoming signal type.
Good luck!
Mitch - Jack_SprattExplorerMenu
Channel
Antenna/air——cable—-hdmi. Select cable - GermaniaExplorerMake sure your tv set is on chan 3 or 4,turn off antenna amp, There could be more switches and whatnot depending on your setup.Make sure your tv is set to correct source
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
