luberhill's avatar
luberhill
Hooked up to cable and no picture
What do I have to do ?? It worked fine on anyenna
  • Power the OTA power off
    Go into TV menus, select cable
    Scan for channels
    Watch Cable TV
  • Turn your wall ant power supply (some wrongly call it the amplifier) OFF.
  • Jack Spratt wrote:
    Menu
    Channel
    Antenna/air——cable—-hdmi. Select cable
    On most TVs you then need to scan for channels.
  • Yea I don’t think you want the tv in 3 or 4 because there is no cable box
  • Combo of what Germania and Jack has posted. Turning off the antenna amp is the first thing, then do the TV incoming signal type.
    Good luck!
    Mitch
  • Make sure your tv set is on chan 3 or 4,turn off antenna amp, There could be more switches and whatnot depending on your setup.Make sure your tv is set to correct source
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: Feb 21, 2025
